alfa147x Lifer Jul 14, 2005 29,307 106 106 Jan 10, 2007 #1 I need to connect to my home computer from school but i can't install any thing on the computer at school!?! But there running windows Xp. thanks!
E elkinm Platinum Member Jun 9, 2001 2,146 0 71 Jan 10, 2007 #2 You may be able to use remote desktop if that is what you need. That is what I used.
N nweaver Diamond Member Jan 21, 2001 6,813 1 0 Jan 10, 2007 #3 rdp (remote desktop) is installed on windows XP Ultra VNC has a java?? based viewer, if you have Java installed on the school computer
alfa147x Lifer Jul 14, 2005 29,307 106 106 Jan 10, 2007 #4 Originally posted by: nweaver rdp (remote desktop) is installed on windows XP Ultra VNC has a java?? based viewer, if you have Java installed on the school computer Click to expand... Yes they do (we code in java). Um...are there any recommended tutorials on how to set one up available?
J jlazzaro Golden Member May 6, 2004 1,743 0 0 Jan 10, 2007 #5 http://www.uvnc.com/features/javaviewer.html
M marulee Golden Member Oct 27, 2006 1,299 1 0 Jan 12, 2007 #6 Originally posted by: jlazzaro http://www.uvnc.com/features/javaviewer.html Click to expand... Guess if it is not behind the firewall..
A AnMig Golden Member Nov 7, 2000 1,760 3 81 Jan 12, 2007 #7 "logmein" is the way to go. its web based and easy to use. I use it at work to browse sites that are blocked from my home PC. I tried Ultravnc in the past but it sometimes hangs the remote pc.
