I need some overclocking help...how high is it possible to run pc133 memory at?
I've seemed to hit my max at 153mhz, cas2. How high should generic pc133 be able to run on a via kt133a chipset? Thanks,
--dave
Yes ramsinks work sometimes giving you an extra 10-15 mhz or so. I don't know what the physical maximum of your ram is. I have heard of people getting higher then you though.
Ok then, any suggestions on what type of ramsinks to get? And where is a good spot to buy them? Thanks guys for the info.
--dave.
