I need some modding ideas!?
50
Okay, I have a Chenming X-Pider case. All that's in it is a small blue CCDFL. I want to make this thing look much cooler! What do you guys think? Crystalfontz? Blue lights all over tha place? UV lights? I have no idea how to do watercooling don't say that. Oh, I have little to no modding expierence, so I will probably have someone to do this stuff for me, so tell me your craziest ideas! Oh and the budget would be no more than 200 bucks. Thanks
well once you get some ideas i would love to do just about any modding you can think up for you since you are looking to out-source it. $200 should put togetehr a nice setup. teh standard mods are as follows:
Steath your opticals
add a window(you already have one though)
add fans for functionality
re-color your leds on the case to match your color scheme
add a little more lighting
re-color the inside of your case
maybe some custom paint art on blank side
replace fans to match color shceme
etc
EDIT: and if you are going to outsource for the modding you could have them set-up the water system too then you could just attach the blocks.
one more idea is to re-paint the outside too I would l think you are happy with the color though.
a feaux fish tank on the side similar to the one at X-oxide would be quite origonal.
