- Mar 10, 2007
- 3,683
- 631
- 126
My case specifies that it can support a 120mm or 240mm radiator on top and has screw holes to attach the radiator but I've ordered two different 240 AIOs and the radiators don't fit. I've never used an AIO before so I don't understand what I'm missing or why the AIOs that are listed as 240 don't fit the case. I tried installing an Arctic 240 and while the radiator doesn't even fit inside the case, the screw holes wouldn't even line up so I removed the front panel and all the screw holes align with a 280mm radiator. So I sent that one back and ordered a different 240 but yet again, the screw holes match the 280mm holes on the front of my case and doesn't fit in the top.
What am I doing wrong? Am I wrong in thinking a 240mm radiator should fit in the top of the case that's clearly marked for a 240mm AIO? I'd like to get the correct one because my new PC is basically a 30lb paperweight right now until I can get the correct AIO ordered and installed.
