Aharami
Ok this is about my gf's computer. Her system clock kept on resetting at every reboot...simple fix - replace her CMOS battery and reset CMOS jumper.
Course of events for background and clarity:
- installed WMP11 via windows update
- tried playing a video file...
- WMP11 did a validation to see if copy of XP is legit. (she might have a pirated copy of XP. not sure...her dad set up the machine for her)
- after that finished, video started playing
- halfway thru noticed that her new keyboard and mouse arent working
- turned comp off via power switch and decided that this would be good time to install a new CMOS battery in her comp
- installed new CMOS battery, cleared CMOS settings via jumper
- put jumper back in 1-2 position and reconnected power wire to PSU
- but as soon as i plugged wire in, comp started up (without me pressing power switch on case). But nothing on screen - vid card connected and VGA cable connected
- Ive tried disconnecting everything - power switch connectors, IDE cables, RAM, sound card, vid card from motherbaord. But as soon as I turn on PSU, CPU fans, case fans, HDs turn on...but nothing posts on the screen. Whats curious is that everything turns on as soon as PSU is getting power - as if motherboard's power on switch is being completely bypassed
Now Im thinking two possibilities - either I discharged some static electricity while replacing her CMOS battery and fried the motherboard (not likely since I grounded myself before working on her comp) or WMP11's XP validation did something. Question is, what happens if XP validation decides that copy of XP isnt legit?
Another possibility is that her PSU isnt working correctly...but she has a fairly new Antec 350W Smart Power supply..
any thoughts? Ideas? I'm at a total loss as to why everything is powering on a soon as PSU is getting power...
thanks in advance
Tech support is thataway <------
AnandTech Moderator
thanks in advance
AnandTech Moderator
