- Jun 5, 2007
- 5,637
- 24
- 81
So I got the XBOX 360, the PS3 and the Cable box all in a small cabinet under my tv. There is absolutely no ventilation and there is about an inch of space between the consoles and the walls of the cabinets. Both the XBOX and the PS3 get super hot. I have to leave the glass cabinet door open all the time...
So I was thinking of a ghetto semi-solution: I have a 120mm case fan lying around somewhere. After playing around with the wires and with a 9-volt battery, I made a fan which does cool the whole mess while I'm playing XBOX or watching a bluray. However, the battery lasts for about 6 hours and then it dies. I need a better solution.
So I thought about the cable box: it has a USB port. How hard would it be to take a usb cable, modify it so that it powers the fan and VOILA!!! cool air for ever!! no batteries!!!
Is that possible? Safe? How do I do that?
Wrong forum. You've been warned about this before.
vi edit
Off Topic Moderator
vi edit
Off Topic Moderator
