I need some advice on Overclocking ASROCK DUALSATA
isekii
28,578
My components.
ASROCK DUALSATA2
Opteron 144
OCZ DDR500 2 x 1gb 3-4-3-8
ATI AIW 9800pro
Maxtor 300gb SATA
Antec Smart Power 2.0 500watt PSU
I go in the bios and have no clue what to play around with.
People that has a similar setup with similar motherboard.
What settings should I be playing with ?
emilyek
511
CHange CPU-North Bridge from 'Auto' to 800
Ram Voltage 'high'
Ram ddr400
Set your ram timings manually 3-4-3-8 (Don't use autodetect)
Flexibility Off
Cool N Quiet OFF
CPU/PCIE overclocking 'Async'
Primary display on AGP
Ram command rate 2T
cpu volts 1.45
Leave 'read preamble' and 'pci latentcy' in the 'advanced memory timings' at defaults--although you could try 6ns and 8ns, respectively.
Turn up the cpu mhz to 250. Enjoy 2.25ghz.
274 is the max fsb the board will do will official bioses. If you go for 274 fsb (i.e. 2.5g) you will need to use a ram divider-- as in, change ddr speed from ddr400 to ddr333.
For unlocked bioses, go to www.ocworkbench.com
isekii
28,578
Ram Voltage 'high'
Ram ddr400
Flexibility Off
Cool N Quiet OFF
Ram command rate 2T
cpu volts 1.45
Cool. I'll look into that
I heard people running 2.7 - 2.9's on these baby ez so i'll see what I can get on it.
