Hi all. You guys seem to be very informed in all the details about computers that most people will never hear about in their entire life. I have a couple questions regarding which hardware would be a better choice for certain circumstances..
1st. If I have a 133MHz FSB (or 266 I guess you could say) Athlon XP CPU, would PC3200 DDR be a better choice than PC2700? I swear I read somewhere that PC2700 actually is a better choice than PC3200 because of reasons that are beyond me. I might be wrong, but maybe you guys know more about that. Some people claim that the higher the number after it says "PC", the better the memory will perform. Maybe, maybe not, that's what I'd like to know. I'm planning on purchasing an Athlon 64 when it comes out, and I'd also like to know which memory would best be corresponding with it as well.
2nd. Which brands of memory are really good? Right now I have Kingston PC2100 ECC Registered DDR (I have a dual Athlon MP 1900+ rig), and my question is how does Kingston compare to the top brands? And what brand(s) of memory would be the best for overclockers and non-overclockers? I don't do any overclocking, although that time is soon approaching for me.
3rd. When the Athlon 64 comes out, is it still going to use the Socket A interface, and would an nForce 2 chipset support (or support it well) an Athlon 64? The Epox 8RDA+ mobo is looking like a pretty good buy right now, and if the Athlon 64 will work, and work well with the nForce 2 chipset, I'd like to buy the 8RDA+ ASAP. If the Athlon 64 will require another mobo, I'll definitely hold off on the 8RDA+. Oh yeah.. When people refer to the "Barton Core" are they referring to the Athlon 64?
4th. Are you guys hyped for the Athlon 64? On a scale from 1-10, what do you guys think about it (the anticipation I mean)? I have to say that I am hyped. I don't even know how it works, but a lot of websites are building quite a bit of hype from this thing. They make it out to be some processor that will revolutionize computing or something. Some of the extremeists out there even claim that AMD will have a vast (over 90% in some cases) majority of the CPU marketshare when the Athlon 64 arrives in the retail channel, but I don't know anything about that.
5th. Is a serial ATA HDD worth purchasing? Are there any SATA drives available on the market, if so, which ones are good?
So yeah that's like 80 questions, but if someone out there has the patience and the knowledge to answer all these, it would be very appreciative.
If you want to email me about it, you can send one to me at MrEgo19@jasnetworks.net, but I know most of you guys want to show off your skills and post your reply in this forum.. ha ha.. oh well, nothing wrong with showing off some well deserved intelligence.
Thanks.
Thanks.
