Originally posted by: fyleow
Originally posted by: OulOat
Originally posted by: Cogman
Just a few questions, First would
this work to charge a laptop? It does not say laptop in the discription, but it has a 12V output, and I belive that is what my laptop uses. Next, If im going to get a laptop for myself, Im concerned about the battery. I want it to last as long as possible. Would a AMD XP Mobile, or Pentium 4 (mobile?) last longer.
I really doubt that would work. First, it's not alternating current like in the walls. Second it's not enough Volts. Third, i doubt you want to carry that around with you since laptops are made to be portable. Finally, for your second question, P4 easily.
Uhhh the laptop has a transformer box that converts the AC current into DC.
You need to check the Ampere rating of your power box and the solar panels. If they match up it should work.
The Mobile XP and P4 should work just as well, you need to be careful that you don't buy a notebook with the desktop processor (P4) though or battery life will be very short. Careful with some laptops as well, Tomshardware had an article up where the Dell worked at half speed while on battery.
EDIT: Checking out the link it gives about 70mA on the 12V line. That is probably not enough, it can power my headphone amp maybe but definately not a laptop.
