I need help !
dantheman123
hi i have an acer aspire 1350. i want to upgrade my video card does any body know which video card would be best to update to and compatible with my laptop thanks alot dan
Syntax Error
617
Laptops are near-impossible, if not impossible to upgrade. You are out of luck.
Your ONLY hope is that if your laptop's graphics card is MXM compatible, but even then, there are many obstacles that prevent you from upgrading (MXM is not a widely accepted standard).
So, the short answer is, no you cannot upgrade your graphics on your laptop.
