i need help with videocards
skateis2s
31
can someone help me out understanding video cards
like which is the best on the market right now and why?
how does the radeon 9700 pro compete against the ti 4800se?
thanks whoever helps! :)
DClark
430
The Ti4800 doesn't compare to the Radeon 9700 Pro (the 9700 Pro is much faster and is a Dx9 card, instead of the Ti4800's Dx8.1 capabilities), but it's debateable which is the best card on the market right now. Some say it's the Radeon 9700 Pro because of its FSAA performance and actual availability, while others say it's the GeForceFX 5800 Ultra due to its faster raw performance, but it doesn't have the availability of the 9700 Pro. There's also the Radeon 9800 Pro, but that won't be in stores until early April.
But choosing the best card for you also depends on the rest of your computer - there'd be no use putting a Radeon 9700 Pro or GFFX 5800 Ultra in a machine using a P3 933 or 1Ghz Athlon; the processor couldn't take advantage of the cards' power, so you'd just be wasting your money on a more expensive card than you needed.
Keysplayr
21,211
50
Out of those two cards (which both ROCK!!) the ATI is the clear dominent card in all areas.
Keys
