I need help with settings for my new Epox 8K7A
Eltano1
1,897
I bought the above mentioned board to go with an AMD 1500 XP cpu and DDR memory, and I don't want to screw up with the jumpers, I need to know what settings to use for the cpu Vcore (JP2), DDR Adjust (JP3), CPU Clock (JCLK1) and the CPU Ratio (SW2). I'm not planning to OC so it will be a regular setting.
Thanks in advance for the help.
Eltano
blackhawk
2,690
Do you have the manual? Without overclocking just use default for the first two and auto for the other two. If you dont have a manual, visit the epox website and download.
Another good site is www.amdmb.com which has forums with mfg specific columns.
Its a great mobo by the way.
Eltano1
1,897
Thanks, yes I do have the manual, but I wasn't sure and I don't want to screw up my first AMD setup.
Thanks again a best regards
Eltano
Eltano1
1,897
I forgot to ask about the CPU Clock, my cpu is an AMD XP 1500, what I don't know which one to select, 100 or 133 MHZ.
Thanks again
Eltano:eek:
