How do you get a level to work? I downloaded one called the Matrix from FilePlanet and it said to create a folder in the Q3 folder and unzip the files to there. I did that but can't seem to get to play the level or use their bullet time or anything that they said that the level would do. What do I do? Did I miss something? I tried to open the files with the Q3 exe file but no luck. Can anyone help?
