I need help with O/Cing on a BP6!!!!!!!!!!!!
myztikal47
1,514
I tried to O/C my 366 celly's, but everytime I changed it in the BIOS, it went back to 300 instead of 366, and said the the speed has been changed and is incorrect. Also, how do I get it to 550? theres no 550 option. Also, I can't use win2k with is cause win2k is giveing me ASPI or ACPI errors, say the motherboard dosent support it. Please help me!!!!!!!!
SupAcHinK
111
You need to get the win2k drivers for the hot rod ata/66 on that bp6. Look on the abit site you should be able to find them. That should solve the win2k error. As for your overclocking check to see if you set the multipler to 5.5 Then set your bus speed to 100mhz(1/3) put your agp on (2/3). That should do it. Oh and disable any speed check hold on that bp6. If that doesn't help then check the voltage on that thing and post back here.
MadRat
11,999
307
You need to pop the heatsink off your chipset (two removable plastic plugs hold it on) and put some thermal paste between the chipset and heatsink. Sometimes those buggers do not even touch!
