I need help with Memtest
ManBearPig
It doesnt boot up when i have memtest on the floppy. I think something is wrong in the bios. It said enable floppy boot or something, and i set it to yes, but still nothing. Help?
i cant find that, it says cd rom, (i assiume it means dvd rom too), removable, and hard disk. ive tried removable first, and nothing
Use the arrow keys on your keyboard to jockey yourself around to where you want to be and then use the + and - keys to change values. Ther should be one that says floppy. Also can hit enter and a small menu may pop up. Depends on the mobo maker and BIOS. If you have a CD/RW drive, you might want to try getting Memtest86+ as an .ISO file and burn it to CD. Then boot from the CD you created.
