I need help with memory.
larrys2006
19
I will be overclocking a i920 on P6X58D-e and I do not know what brand and model to get, I am looking for 6 gig in a triple kit. Can you help?
vmbgap
www.totalandroid.co
I currently use Corsair Core i7 Dominator 6GB PC15000 DDR3 RAM in a similar config. It really depends on you budget and personal preference I have never had any problems with Corsair memory. If you are looking for something a little less expensive I would recommend this Core i7 Dominator 6GB PC12800 DDR3 RAM.
Both can be purchased at Tigerdirect and if you buy through the site when you click that link you will get and extra 2% off!!
