I need help with 20' CRT
colonel
1,786
21
I got this Gateway VX11200 CRT , I cant find drivers. The monitor is slow with high resolution . What can't I do? I using the 7800gs EVGS video card.
thanks
xtknight
12,974
20 foot CRT? Wow :D
What you need to do is find the horizontal and vertical frequency ranges for your monitor (or the preset VESA timings table) so that you can choose a refresh rate that won't damage it. The NVIDIA video control panel should have refresh rate forcing options.
CP5670
5,663
765
If you know the monitor's specs (the horizontal scan rate, in particular), you can make your own inf driver file for it. Rivatuner is the easiest way to make it.
Rankor
1,667
Here you go.
It's a Gateway VX1120 22-inch Flat-CRT Monitor right? This should be the drivers. These are for XP, but there are drivers for 2k, 9x, and Me.
