My current setup is this.
VisionTek Geforce4 Ti/4400.
28.32 Detonator drivers.
Dual Monitor setup - My main monitor is connected to the VGA out, and the secondary monitor is connected to the DVI using DVI - VGA converter. Both are set to 1280 x 1024 for everyday tasks.
Now the problem came when I installed half-life and counter-strike. I don't know if there are special settings I need to do or what. Plus i don't know what to use, opengl or directx, and what resolution to set the game to.
Problem 1.
The smoke bombs are terrible. The smokes look all big white squares, and I didn't even have this problem with ATI Xpert 2000 card.....
Problem 2.
When I play the game on the main monitor, the second monitors resolutions seems to change also, and I can't really see the open windows on the second monitor. I heard people play games on one monitor, and see AIM or whatever on the second monitor when they have dual monitor setup.
Please, I am sure there are someone using the same card and playing counter strike. Is there any certain settings I need to do? OpenGL or DirectX? How can I make the smoke bombs smooth and actually make it look like smokes?
Thank You!
Problem 1.
Problem 2.
Thank You!
