can a gddr5 fit in msi fm2-a85xma-e35 motherboard ??
1 PCI Express gen2 x16 slot
2 PCIE 2.0 x1 slots
Source: http://www.msi.com/product/mb/FM2-A85XMA-E35.html#?div=Detail
GDDR5 is memory which is on the VGA...
Your motherboard has the following PCI-E slots according to MSI:
If what you wanted to ask is if a PCI-E 3.0 VGA can work in a PCI-E 2.0 slot the answer is yes.
ok thanks so i can put any 7000 series on this motherboard: http://www.newegg.com/Product/Produc...82E16814125455
Yes, it's backward compatible.
