I need help how to connect android phone to car stereo
Status
Not open for further replies.
Remobz
Hello guys,
In need of some advice here.
I have an Android AT&T Fusion 2 GoPhone and would like to play music from the phone through my car stereo.
I have an older 2003 Mazda Tribute OEM factory stereo player but it has NO 3.5mm input jack.
Here is a picture of my stereo......
http://www.hifisoundconnection.com/...er-Cassette-CD-Player-BOSE-OEM-Radio-R-2440-5
As you can see in that picture there is a CD and cassette player but no 3.5mm input jack.
Besides that I have a car lighter and below that an Aux input that says 12V.
Here is how the 12V Aux input looks like....
http://www.escape-city.com/viewtopic.php?f=13&t=8766
So what choices do I have to connect my android phone to car stereo in order for me to play music?
I am hoping to order something from Amazon (links appreciated).
Get a new stereo. Be sure to get a wire harness that converts from the standard connection your car uses to the one the stereo uses. It's much better than splicing wires. 🙂 (AskmehowIknow)
http://www.instructables.com/id/Adding-a-direct-line-in-to-your-car-stereo-for-an-/
try this. personally, id get a new stereo that had the jacks i needed rather than keep the old oem and mod it. since i cant afford one for my wagon, i use the cassette adapter. sounds like shit.
Yeah, I don't want mods because I rather just get a new up to date stereo. I doubt the cassette adapter will sound good anyway.
For now, I will just burn some CD's because my player can hold up to 6 cd's at a time. Will just have to save up for a decent up to date modern car stereo player within the year and do a proper upgrade.
Cassette adapters sound pretty good. Quite a bit better than FM adapters anyways. Only real downside is that you have cables just hanging out of your dash.
if your oem stereo supports a CD changer or satellite radio, you can probably get an adapter that will allow for an aux input. those tend to run around $100 though.
edit: NM, cd changer is built in and car is too old for xm...looks like a new stereo is your only option unless you want to mod your OEM or use a tape adapter.
Status
