Originally posted by: Howard
The wall is going to be covered by the mirror, right? Hammer in nails/screw in screws in random spots. If the nail goes in too easily, or the screw keeps turning when it goes in all the way, the stud isn't in that spot.
Once you find that spot, the stud is at that spot and can be used to anchor the mirror at any point vertically above or below it. Also, the studs should be 16" apart, center to center (I think.)
YOU SICK BASTARDOriginally posted by: trilks
Come on, admit it. By "wall" you mean "ceiling". 😉
