I need help from ATOT ghrapic imaging experts!
well its nothing extraordinary..
I have this phone rebate file. but when i print it, it comes out all blurry.. tried it on a laser printer.. same result..
Can someone fix it up, so its clear? and here is the file. thanx!
T-mobile rebate 🙂
The only way you're going to get that to come out clear is to retype all the text parts, or scan it at a higher resolution.
Amazon has a lot of crappy low res JPEG rebate forms. Just print it out as it is and send it in. Hopefully, they can figure it out on the other end.
How about some help from an ATOT "graphic" expert? 🙂
Hmm ... there might be some results from applying aggressive line-based sharpening filters after enlargement. Any Photochoppers want to give that a shot - I don't have it installed ATM. 😱
- M4H
doesn't matter.....u have to work w/ that pic as is.....i printed ..it came out fine....i just put the DPI to the max (1200 dpi) and darkness to the max.....and it came out fine...
