Where would I find this driver file? My software dropped support for a hardware interface I use and so they remove the driver in the next update. I'm thinking if I can find this driver file I can drop it back in place and all will work still.
Thanks for the help. Your right it is a intel nic card in the computer but it is a pci->to pci-e rack adapter that uses the ethernet. So I don't see the kext there. I was just wondering if there was a way to see where this driver is located that it sees. When I do the update this page is the same but it says no driver. I'm thinking the driver might be embedded in the program contents.
ok this is the report. I think its all the 6311ESB stuff specifically the PCI Express to PCI-X Bridge. I guess I don't understand what I'm looking at. How do I get from here to getting the driver?
You've managed to hit on one of my few complaints about the platform: overall it's pretty damn hard to figure out what drivers/kexts a certain piece of hardware is using. So figuring out by hand can sometimes take a great deal of sleuthing.
Thanks 🙂 When money is on the line a little work isn't so hard hahaha.
So is it possible to edit into the kext the stuff I need out of this one? Or are these things blocked up pretty good. I'm worried about removing the newer kext file and replacing it with this one. It might not matter I guess but I think it points to 8.0.1 all over the place inside instead of the newer version 8.0.3 not supported by my expansion chassis. I guess I could just try it later on.
