I need help converting data to hex
LeetViet
I'm trying to figure out what
0b 00 00 00 00 00 00 00 03 00 00 00
is in hex
I know that
0b 00 00 00 00 00 00 00 01 00 00 00
is 0xff
Any help is much appreciated. 🙂
ok here's how:
start menu->run->calc.exe
scientific mode enable
switch to binary
enter the binary number
then switch to hex
voila
is in hex
I know that
is 0xff
Huh? That IS hex. What other number system would have 0b?
Originally posted by: dighn
ok here's how:
switch to binary
then switch to hex
voila
I can't enter the letter B in Binary...
ok here's how:
switch to binary
then switch to hex
voila
0b simply means the number after is binary
0x means the number after is hex
so don't enter those parts
is in hex
I know that
is 0xff
Which system uses the 0x_ _ _ _ _ _ ... ?
ok here's how:
switch to binary
then switch to hex
voila
Binary has a 3?
is in hex
I know that
is 0xff
hex.
is in hex
I know that
is 0xff
hex.
And how would I go about converting 0b 00 00 00 00 00 00 00 03 00 00 00 to 0x _ _ _ _ .... ?
Sorry I'm a total noob.
dang this is sooo easy guys.
Here's a table of translation from bin to hex
first column is binary : second column is hex
0000 = 0
0001 = 1
0010 = 2
0011 = 3
0100 = 4
0101 = 5
0110 = 6
0111 = 7
1000 = 8
1001 = 9
1010 = A or "10"
1011 = B or "11"
1100 = C or "12"
1101 = D or "13"
1110 = E or "14"
1111 = F or "15"
So you take every four bits and it turns into one hex digit.
so like:
0b 00 0000 0000 0000 0100 0000
0x--0-----0-----0-----0-----4-----0 (the very first part of the binary data has only 2bits "00" that still = 0 in hex)
0x000040
So let's do the one you were asking about...
0b 00 0000 0000 0000 0300 0000
0x--0-----0-----0-----0--??!?! <--- what the hell? You can't have a 3 in binary!!!! 😕
I give up. :/
Write an 0x in front of it? I dunno. I don't know where you're getting this data from or what, but all I know is that hex is the only number system I know of that has 3's and b's; binary only has 0 and 1, and decimal and octal don't have letters.
