I need help configuring my PC
goofivee
I have this processor... http://www.newegg.com/Product/Product.asp?Item=N82E16819103539
and 2 gigs of this ram... http://www.newegg.com/Product/Product.asp?Item=N82E16820227211 . I have my processor overclocked to 2.61ghz and everything runs cool like 34c idle, and 42c load. I ran CPUZ on my computer and took a screenshot of results that it showed for my processor... ProcessorInfo . I was wondering if everything there is set correctly? I also took a screenshot of my ram stats from CPUZ and it looked like thisw... RamInfo . I have no idea what specs my ram should be running at, so I was hoping that maybe someone that knows what they are doing could look at the ram I have(from newegg link) and tell me what I need to fix/change to make my ram run like it is suppost to.
Edit: To make the ss I took readable depending on what broswer you use you may need to zoom in once and it will be clear as day.
