I need Econ help!
babypanda
Can someone please help me with this question? I feel like such an idiot because it's part of a group assignment and I don't want to let the rest of my group members down...
"Suppose the demand for a particular product can be expressed as q=100/p. Calculate the total amount spent on this good when p=10, 20, 50. Can you make a generalization about the mathematical form of this demand curve and consumer behavior in the market?"
My thoughts are to plug in p into the equation q=100/p, and then multiply PxQ to get the total amount spent.... Does that sound right?
p=10
q = 100 / p = 100/10 = 10
so q = 10 and p =10 => total amt spent = p *q = 100
edit:
to generalize
p= x
q = 100/p
q = 100/x and p = x => total amt spent = p *q = x * 100/x = 100
<- 6 credits way from getting an econ degree
what would this say about the consumer behavior regarding this demand curve? All the answers are 100....
Thanks for everone's help btw.
-Sarah
q=100/p
so if p=100 q=1
if p = 50 q=2
if p = 25 q=4
if p = 10 q=10
if p = 1 q=100
So q changes dramatically based on p. When p is 100, q is low. When p is 1, q is high. As p increases q drops in a hurry and then tapers off. You should be able to grab a piece of paper and a pen and make a simple qraph, can't you?
-Sarah
The function means that the consumer will demand more if the price is low, and less if the price is hight. This is a typical demand function.
<--- Econ/CS degree
q=100/p ==> p * q = 100; when p=10, q=10; p=20, q=5; p=50, q=2. Graph it out and draw a line through it, then realize that the function is going to be asymptotic as the function draws closer to each axis. (hyperbolic, I think)
As alexeikgb said, this is a typical demand function, except for the axes. As P goes from $1 to $0 per unit the quantity demanded increases rapidly (asymptotically, again).
<--- been way too long since he's looked at demand functions, I'm knee-deep in acctg at the moment.
It's hard to determine exactly what kind of response to give because we're not sure what class level you're in, what material you've already covered, etc.
draw a graph
x axis = quantity
y axis = price
the demand slope downward. so you will see when price is $10, you get more, the quanatity you can get decrease as the price increase.
