I need a video capture (and TV tuner) card for European standard.... PAL
ManuTOmanU
1,165
I don't know where i could get one...
is there anybody that had the same problem, and has an advice....
are there any links...
I was hoping to get the hauppauge PVR or one of the AIW...
or maybe there is a different one out, MPEG hardware decoder is important for me, as well as i need PAL standard, and a TV tuner....
Furthermore i need to be able to connect a vcr to input and output...
astartz
550
The all-in-wonder 128 pro will do that. All you need is a SCART connector. Reply with any questions.
August Startz
ManuTOmanU
1,165
Ok....
<< All you need is a SCART connector >>
so you mean that i could connect the card with my VCR and then recieve the channels?
Or what?
In case you know something about the AIW card, can you let me know if there is a difference between the ATI all in wonder RADEON and the ATI all in wonder 128 pro (in respect of TV tuner and MPEG2 capturing?)
That because I am definitely not doing any big games...
you know... all i need it for is for capturing tv and inputting and outputting video from and to a VCR...watching TV and stuff like that..
DieHardware
1,706
You could use the tuner in your vcr, use the video out of vcr to video in of videocard/capturecard.:)
astartz
550
The difference in cards is the all-in-wonder does not supports digital out. The other differences won?t matter to you. NOT WORTH THE MONEY!!!!!!!
I do video capture for a living and the All-in-Wonder 128 pro is fine for what you are doing.
email with questions
