I need a tv box
You just need to compare the specifications of both, then match them to the features you want to get while adjusting to your budget.
Hi guys. I need a tv box. What should I buy? Xiaomi Mi box or Next Star pro?
Are you in the USA? If you are and depending on your desired features/needs, I would also consider the Onn 4k Plus.
Where are you located?
What features are you looking for?
What's your budget and currency?
I am in turkey, Just open YouTube.
My budget 3000 Turkish Lira (70 USD)
Here are some recommendations courtesy of Google Gemini AI which is free. I'm sure @Kaido can do a better job in prompting for better results.
Based on the current market in Turkey, with a budget of TRY 3,000, you have several excellent options that offer great value and performance. The most common devices available are from Google, Xiaomi, and Amazon.
Here are the 3 best streaming boxes to consider, ranked by overall value and performance within your budget:
1. Xiaomi TV Box S (2nd Gen)​
This is arguably the best all-around option in your price range. It offers a great balance of features, performance, and affordability.
  • Why it's a top choice: It runs on Google TV, which provides a clean, user-friendly interface with access to all major streaming apps like Netflix, Disney+, and Amazon Prime Video. It supports 4K resolution, Dolby Vision, and Dolby Atmos audio, ensuring a high-quality viewing experience. The included remote has a built-in microphone for Google Assistant, making voice commands easy.
  • Availability & Price: This model is widely available from major electronics retailers and online marketplaces in Turkey. It typically falls well within your TRY 3,000 budget, often costing around TRY 1,500-2,000, depending on the retailer and current promotions.
2. Chromecast with Google TV (4K)​
This device is a direct competitor to the Xiaomi TV Box S and is a favorite for those who are already integrated into the Google ecosystem.
  • Why it's a top choice: It offers a very similar feature set to the Xiaomi, including 4K resolution, HDR support (Dolby Vision), and a smooth user experience powered by Google TV. Its seamless integration with a Google account and the ability to "Cast" content from a phone or tablet directly to the TV are major selling points. The remote is simple and intuitive.
  • Availability & Price: The Chromecast with Google TV is also widely available in Turkey. Its price is very competitive and generally falls within the TRY 1,500-2,500 range, making it a great value for the features it provides.
3. Amazon Fire TV Stick 4K​
This is an excellent option, especially if you are a frequent user of Amazon's services like Prime Video.
  • Why it's a top choice: The Amazon Fire TV Stick 4K provides a fast, responsive streaming experience with support for 4K Ultra HD and Dolby Vision. Its interface is highly tailored to Amazon's ecosystem, making it a great fit for Prime members. The Alexa Voice Remote is a powerful tool for finding content and controlling your smart home.
  • Availability & Price: Amazon Fire TV Sticks are commonly found in Turkey and are well within your budget. The 4K model generally costs between TRY 1,500-2,500, making it a strong competitor to the Google-based devices.
Final Recommendation:
Given your budget, both the Xiaomi TV Box S (2nd Gen) and the Chromecast with Google TV (4K) are the best overall choices for most users. They offer similar performance and features and are both excellent values. The choice between them often comes down to personal preference for the user interface. The Amazon Fire TV Stick 4K is a great third option, particularly if you heavily use Amazon Prime.
Of the choices provided in the previous answer, the Xiaomi TV Box S (2nd Gen) and the Chromecast with Google TV (4K) are the best for streaming YouTube. They both run the official YouTube and YouTube TV apps and offer a seamless experience.
The key advantage of both is that they are Google-certified Android TV or Google TV devices. This means they have the official, full-featured YouTube app, which is optimized for the TV screen. Both also have deep integration with YouTube services, allowing you to easily sign in, manage your subscriptions, and use the voice remote to search for videos. The Chromecast, in particular, has the added benefit of being able to "Cast" YouTube videos directly from your phone, which is a very convenient feature for many users.
Also here's a comparison of the two streaming boxes you asked about:
Xiaomi Mi Box vs. Next Star Pro​
This is a comparison of two different categories of devices, which makes a direct comparison tricky. The "Next Star Pro" is not a widely known, established brand like Xiaomi, and its name is often associated with generic Android TV boxes, many of which are sold on various online marketplaces.
Here's a general comparison to help you understand the differences:
Xiaomi Mi Box (or Xiaomi TV Box S)
  • Official Google TV / Android TV: The Xiaomi Mi Box S (and the newer 2nd Gen) is a certified Android TV/Google TV device. This is its biggest advantage.
onn is hard to beat for the price. Add Projectivy Launcher & a U.S. VPN (recommend using a cheap dedicated router). Plenty of sideloading options! Works great with a wireless Xbox gamepad as a controller!
Gotta be careful out there
