It's a good thing I had to install Swish for a recent project. 😉
Did you enable the Color panel ? It's hidden by default. Go to Panels --> Color. Make sure the "over state" of your button is selected, then use the color panel.
Do I win $2 ? 🙂
love your sig, but not yet. PM me for the file... it's basically like how buttons are in the sprite, so that i can't access the individual objects in the sprite.
