- Mar 6, 2006
- 6,490
- 1,022
- 136
Ive been trying to figure out how to setup a house audio system...and I think I finally figured out what I need. Im looking for a dual zone, dual source receiver that can run a 5.1 surround system as well as a whole house audio system (at the same time) which is basic stereo (2 speakers each room, one left and right in ceiling). Id like to be able to get network/internet sound throughout the house. Right now this is the model Im considering for the receiver: http://www.amazon.com/Onkyo-TX-NR609.../dp/B004O0TRD8
Any help or alternative options you might have for the receiver part would be helpfull too. My origional budget was $1,000 for the receiver, amplifier, and 5.1...but it seems the speakers may have to be a later on thing. Im trying to get some quality mid range stuff that will last a very long time even though the demands arent that high. Just want something better than TV speakers, especially so we can hear voices/talking (were all basically hard of hearing/tone deaf) Just doing cable/sat TV, DVD/VHS, and AM/FM radio, reception on radio isnt great here though so thats why Im looking at computer/internet radio options (especially if it easily works with any wifi network).
No consoles or gaming devices, nothing here even has HDMI...but we might like to use the laptop to play pictures/video if possible, not a requirement (its old and VGA only). Theres a small chance that eventually the computer will get upgraded to something digital (with HDMI), and a very small chance that we get a dedicated netbook or something to hook up permanently (probably way to complicated/expensive to do right now)
RECEIVER /\
AMPLIFIER \/
Unfortunately anything I have used to try to run the whole house system has fried...Im pretty sure theres to much power draw from the single channel (so I dont want to just plug it into the expensive receiver). What Im having a hard time finding now is some kind of amplifier that can handle the load and yet not burn down the house (dont want to put to much power through those little speakers/wires). It also needs to connect to the reciever (just for the house audio, not the 5.1)
The way this place was setup, they installed 2 speakers in each room (total 8 speakers 4 rooms) as well as a volume knob on the wall (turn it all the way down and it clicks to turn off) then ran all the wires to what looks like a simple splitter. That runs down to where the entertainment room is and we had a wall plate stuck in with 4 connectors for the stereo input. Everything was just hanging out of a hole in the wall, it was also already "pre wired" for the 5.1 so those are hanging out here to, and no idea where those go (gotta figure out where they are in the wall/ceiling).
All the audio/video equipment will be there, including the receiver and amp. I need something that can handle running the entire house all at once (when all the rooms are on, like for entertaining guests ect), or just a single room like somebody just in the office ect. I don't know exactly what all is going on with this system, it was installed before we moved in. I can only find a Leviton label, and searching online I think I might have found the speakers: SGC65-W 60w RMS 8 ohm.
Assuming thats correct, I need an amplifier that can provide like 500 watts RMS (750-1000 peak?) but also only as much as is required by a single room...I dont want all 500watts blowing out a single room. Absolute n00b in the audio area, so I have not the slightest idea how everything connects or works...or if an amp is even what I actually need (it sounds like thats what I need though).
SUMMARY: I need an amp that connects a receiver to a stereo whole house audio system and can run very low power (like a single room low volume) up to 500watts RMS (like all the rooms turned on/up).
Thanks in advance, especially if you read the whole thing
Oh and yes I have googled for stereo amplifiers, I find 1000watt units for $90, and 200watt units for $1300...and all kinds of weird stuff I don't understand. And I have no idea what brands are good ect, thats why Im asking.
RECEIVER /\
AMPLIFIER \/
