I need a snowblower
KaRLiToS
1,918
11
I thank you very much. :wub: :wub: :wub: . I thank everyone for the help. I am now an expert in Snowblowers, I studied them so much that I even dreamt about them couple of night. I'm too OCD.
I can't wait to have it Friday.
NetWareHead
THAT guy
Aug 10, 2002
5,847
154
Congrats on your purchase. You will love your Honda. I see you got the tracked model. Find yourself 2 old furniture dollies and position them under the machine when its in your garage/shed. it will be far easier to move the machine this way and you wont need to start the engine
p.s. actually, with the hydrostatic transmission, maybe it will be easy to move. Ive only used snowblowers with a geared transmission...
Meghan54
11,677
5,211
Good choice, except the tracks. Guess you don't have any ice where you are, tho. Congrats!
Zivic
3,505
38
there is a lever in the back you flip side to side to engage disengage the drive to allow it to move without starting the engine.
Scarpozzi
26,389
1,778
Parking lots are difficult to clear with a walk behind snow blower because:
If you start in the middle and blow outwards, by the time you get 15 or 20 feet out, you are now blowing twice as much snow. When you get another 15 to 20 feet out, you are now trying to blow three or four times as much snow. As you get to the outer perimeter of the parking lot, it will be almost impossible to blow. Of course, you can blow the outer 15 feet of the parking lot, and then come back and redo that as you go, but you are doing twice as much work. A plow on a pickup truck would work much easier and quicker.
He stated it was 20'x65'.... The blower would only have to shoot the snow 10+' to clear the edge of the drive.
seepy83
2,132
Congrats on the purchase. I'm sure you'll love it. On a related note, I'm happy to say my ariens compact 22 turned over on the first pull tonight after sitting untouched for 8ish months. Supposed to get 6-8" tomorrow.
KaRLiToS
1,918
11
I posted this picture earlier this week
As you can see, I need to throw the snow whether on the front of my driveway or in the backyard over the fence. I cannot blow it over the neighboors. (On the left of the pic).
I took the tracks model because my GF will use it and I don't want her to force when the wheels are spinning. I also want to clean off the balcony and the tracks will climb the stairs easily.
12,559
I would just push the snow with the shovel from the fence to where the yard is, since you don't have to worry about where you put the snow it will make it easier as you're just pushing the snow and not lifting it anywhere. Then use the snow blower to throw that snow further into the yard.
I got to use my new snow blower the other day but there was only like 4cm on the ground, so I just shoveled to the sides then use snow blower to clear it. With regular shoveling I would have to throw the snow far enough into the yard to ensure there's room for more as the year progresses and for the really big snow falls I'd have to use the scoop to "drive" it into the yard. Usually I'd have some trails and a few hills that I run and slide the scoop up the hill and then dump it, and try to get it as high as I can to make the most room possible.
With snow blower I don't need to worry about that anymore, just push snow in one area then make a few passes with snow blower to get it far into the yard.
Looking forward to the next big snow fall. Bring it on. :D
Meghan54
11,677
5,211
Well, there are chains you can use on wheeled models. Anyway, just repeating what I was told by numerous ex-owners of tracked blowers while I was shopping for a blower on Cape Cod. Almost no one who'd owned a tracked blower would buy a second.....and most had had a hard time selling the tracked blower.
C'est la vie. Enjoy the Honda. It's well built.
KaRLiToS
1,918
11
Ok, I don't know what is up with the Tracks being hard to turn....It is fairly easy, heck, even my girlfriend can do it. She can also start the engine with a weak pull. (She weight 127lbs)
Dang, I can climb stairs with that machine. It is crazy.
This is my machine ready to blow some snow. Filled the tank with Shell V Power (No ethanol) and added the proper amount of stabilizer. I need to put some lubricant silicone everywhere since I want to keep it for 30 years +++.
Also ordered some extra skids for the side of the housing : part number : 76153-736-010
mindless1
8,333
1,550
It is a very bad idea to try to get a snow blower to climb snowy or icy stairs. The chances for an accident are high and with a beast of a machine it's all that much heavier, harder to manage in snow and ice.
Do you intend to store it in a shed with a wood floor? You do realize that after blowing snow, there is snow in every nook and cranny of it that drips off wherever you park it? It might be good to get a shower pan or something to park it in, and I find a small hand broom helps to get as much snow off as possible.
KaRLiToS
1,918
11
Thank you for the suggestion, I was already looking for a carpet or something to protect the floor, and the shed is filled with any type of brooms ;).
KaRLiToS
1,918
11
I just bought a carpet, thanks mindless1 for the great suggestion. :thumbsup:
snoopy7548
8,119
5,143
This is a good point. Be careful, OP. The majority of people tend to shovel, rather than snowblow, their decks. In fact, I've never heard of someone snowblowing their deck... you might want to stick to shoveling it. I could imagine someone wrestling a snowblower up some stairs and ripping into the wood steps, damaging not only the deck but the blades in the process. Even worse, you could end up tipping the machine over or flipping it backwards. People have lost hands and parts of arms in snowblowers by simply clearing out a blockage. Even if the machine is off, never stick your hands into the blades!
LegendKiller
18,256
68
86
I'd never take a snowblower up steps on a deck, that's crazy. If the thing started sliding backwards how would you get out of the way? Sounds like a great way to kill yourself and/or break your deck. How big is your deck anyway?
No offense, but your entire snowblower situation seems like massive overkill. Spending 4k on a tracked snowblower when you have a flat driveway, and a short one at that, is crazy.
KaRLiToS
1,918
11
I love overkill. The wheel snowblower was only 400$ less and there was no stock at my local dealer.
Don't worry guys, I will only clean my 35'*35' one stair deck. The other level, which is almost 6 stairs high will be cleaned by shovel. Actually, I only need to remove the snow around the air dryer air output.
Zivic
3,505
38
How is having a quality snow blowing machine in Canada overkill? Buy quality and buy once. I don't care what anyone says the lesser machines discussed here will not throw snow as well, won't last as long and will have more issues than the Honda. I think that is more than worth the price premium. Just because you dont see value in it, doesn't mean others dont
KaRLiToS
1,918
11
Don't pay attention to him. He bought a deluxe 28, which is a very good machine but according to him, it is the machine that everyone should buy.
I just waxed my machine today and I will spray the entire machine with lubricant silicone in a few days.
cytoSiN
2,262
7
This thread was a good read, but this is MASSIVE overkill for me. I have two driveways, one 60x15 and the other semicircle, about 100' long by 20' at the widest (it's wider at the top of the curve), but both driveways are surrounded by lawn so I don't need to throw the snow very far. Both driveways are basically flat. I also have a patio and walkways, but those don't need to be completely cleared.
What would you guys recommend (sorry to ninja your thread KaRLiToS, but it looks like all the knowledgeable folks are already here, yourself included!)?
12,559
With that big of an area to clear I would not say it's overkill, go for it, even if it's a cheaper one like the Craftsman just posted. My driveway is only 2 car but after a big storm it still takes several hours to shovel by hand. Looking forward to the next snow storm so I can use my snow blower at it's fullest extent.
cytoSiN
2,262
7
Thanks for the suggestions. Am I crazy to be concerned about keeping a gas snowblower in the house with little ones? Not that I'd let them anywhere near it, but still. Garage is one car and fitting one of these next to car would probably be tough.
12,559
My main concern with putting it in the house is that the snow will melt all the time so it will probably rust faster. There may also be residual fumes from having operating it but probably not enough to be a concern. Just take the key out so it can't accidentally be started.
I would build a small enclosure outside to put it in though, just because of the rust issue. It's like if you put your car in the heated garage all the time, the snow melts, and salt starts to work and it will rust much faster.
