I need a small tablet (6, 7, 8 inch category) with wireless charging and a larger than average battery.
shortylickens
80,287
17,080
I'll entertain suggestions for weird off brands and even Lite Windows tablets if they have the requirements.
aigomorla
21,019
3,489
There is no tablet i can think of that has a Qi charge capacity, unless you want to go the mickey mouse route with one of these.
https://www.amazon.com/Nillkin-Wire...rging+adapter&qid=1567118207&s=gateway&sr=8-3
However i highly advise against it... 1amp charge is pathetically slow.
If you want something quick id use a quick disconnect like this instead:
https://www.amazon.com/Magnetic-Charging-Terasako-Compatible-Smartphone/dp/B07RHVNFQ6/ref=sr_1_4?crid=1RWX6TSAZ34MF&keywords=magnetic+usb+charging+cable&qid=1567118279&s=gateway&sprefix=magnetic+usb,aps,184&sr=8-4
You also protect the USB port because one end stays inside your device.
On that note, if you need qi charging, and a large battery life, your probably best off getting a used Galaxy Note 5 phone, but i think the screen maybe a little smaller then 6 inch, but not that much, or you can step up to a note 8 which has a 6.3" screen.
Also i think a LG V20 might also fit... but these are phones and not really tablets.
shortylickens
80,287
17,080
Is Qi the only standard for Wireless charging?
If it limits my options, maybe I will forgo wireless and just look for something with a good battery.
Which is difficult enough to find these days.
