I need a small compact flash reader for a Thinkpad
Originally posted by: isekii
just get a PCMCIA---> Compact Flash Adapter.
it's like under 10 bucks
Those tend to take longer to transfer images than a USB, but thanks for the suggestion.
Those tend to take longer to transfer images than a USB.
Not too sure how big your CF is.
I use a 512mb and they're fairly quick.
Not to mention you can jsut leave it plugged into your computer without it behing a hiderance.
Off the top of my mind, Kingston is one of the only to offer a true highspeed flash reader. Dazzle is also excelant and I can recomend them, their performance is tops. Dazzle was bought out late last year, but some of their last production can still be found for sale on line.
USB
http://www.kingston.com/flash/15in1.asp
http://www.smartdisk.com/b2c/smartdisk/ecom/ecomEnduser/default/default.aspx
PCMCIA -High Speed for Generation 3 flash modules. But do not expect to see extreme speed through the PCMCIA slot, it is slow compaired to usb.
http://www.sandisk.com/Products/Item(11...-64-SanDisk_Ultra_PC_Card_Adapter.aspx
http://www.bhphotovideo.com/bnh/control...CFA&is=REG&Q=&O=productlist&sku=303357
1394 Readers are the best. Lexar makes one but i am sure that you can find it for less.
http://store.lexar.com/?category=22&subcategory=1&productid=RW024-001
