I'm getting a T1 connection but there is only one connection (one jack). I have two ip addresses for two computers but only one jack. So you see my problem. I know I need a hub. Should I go for a switch type hub. Or should I go for a hub like the Linksys one that can also function as a router, for possible future needs when I only have one IP address.
So basically
if I get a router can I still use it as a basic hub with two IP's or will it only let me use one IP address?
if I get a switch for a hub that doesn't have the router feature will I get better performance compared to the router type hub?
So basically
