I need a quick answer about a USB cable.
badluck
5,357
Weird question, I know.....Maybe somebody can help me.
I am looking at buying a digital camera and the Connector Type reads like this:
Connector Type: 1 x USB (4 PIN USB Type B)
Is this Type B for a USB Hub connection (I seem to remember a Type B USB looking different) or will this plug into my USB port on the back my computer like any other USB device out there??
Thanks.....
AndyHui
Administrator Emeritus<br>Elite Member<br>AT FAQ M
17
The Type B is the standard flat rectangle plug at one end and the small square plug at the other end. This one is used by most peripherals and hubs.
The Type A cable has the flat rectangular plug at both ends....usually used for networking two machines. Less common for peripherals.
JERR
348
Type B is a head, but the cable you want would be type A/B male/male.
