C coder1 Senior member Jul 29, 2000 433 0 0 Sep 9, 2002 #1 I need a formula for the following scenerio. Lets say someone saves a $1000 every month in a .07% interst rate. What would be the total after 10 years. thanks for any help.
R rgwalt Diamond Member Apr 22, 2000 7,393 0 0 Sep 9, 2002 #2 What is the compounding period? Yearly? Monthly? Daily? Continuous? Banks compound daily, IIRC. Also, do you mean 7% or .07%? Ryan
C chiwawa626 Lifer Aug 15, 2000 12,013 0 0 Sep 9, 2002 #3 y=P(rate)^t y=value after whatever years P=initial value rate= ur percentage plus 1, so lets say it was 15 percent, then it would be 1.15 t=time in years, if ur doing quarters then instead of t you put t/4, months then t/12
