I need a little bit of help with Homer Simpson
Jeff7
41,596
20
Got any specs on the file?
Windows Media Player can't open it, and Goldwave can't identify the format.
Googer
12,576
7
It's a wav file. Almost any media player can play it. If you are having problems, try the (almost) guaranteed solution: Media Player Classic (OGG, OGM, Real, MOV, almost any file plays on it)
http://sourceforge.net/projects/guliverkli/
http://sourceforge.net/project/showfiles.php?group_id=82303&package_id=84358
Your best bet is to download ACE's mega codec pack professional and it includeds media player classic. When you install it, choose the Hyper Install option.
About ACE Codecs
Download Page
Googer
12,576
7
Also check you volume control on your system tray (or control panel). Make sure that your WAV volume is turned up all the way and is not on mute.
Googer
12,576
7
Originally posted by: iamaelephant
Hhmm, I've never heard that before (or just can't remember it), what episode is it from?
I have not one clue.
NiteWulf
1,112
I don't think it's from any episode. The "peace" and "d'oh" seem out of place, like they were chopped in. The message itself may be from one of the Tracy Ulman sketches, but I doubt it very much
fire400
5,204
21
I found this one on the website, it's hilarious:
"640K of computer memory ought to be enough for anybody."
- Bill Gates, 1981
p.s. I saw the quotes in someone's sig before. Anyway, that's like half of a standard 3.5... floppy disk!
Jeff7
41,596
20
I had just wanted to know specs though - 44.1KHz? Mono or stereo? Once I have that, I can get Goldwave to open the file. If it doesn't know what the input file is (since this file isn't identifying its specs to Goldwave), then I just get a lot of really loud static.
Googer
12,576
7
I believe it is 11khz .
Jeff7
41,596
20
Well this explains things. The file from Freeaudioclips.com was just an html page, with a wav extension. The putfile page worked though.
Can't say I've ever heard this particular audio sampling before.
For the record, it is 11,025Hz, mono.
Googer
12,576
7
The free audio clips page worked for a while, but I think they added a redirect after a few too many unauthorized referrals.
