I need a liquid cooling system with long hoses
BirdDad
1,131
I need it to fit around a video card do it has to be more than one foot two feet would do it nicely. Does any one know of any?
Thanks
BirdDad
1,131
anyone know? TBy double on the radiator must be a radiator that takes one fan slot not two fan slots
BirdDad
1,131
Does anyone know what I am talking about? I need a socket 2011 cooler that has tubes long enough to go around a full sized video card. the radiator is going to be in the bottom of the case.
XavierMace
4,307
450
The NZXT Kraken X61 has pretty long hoses, but I don't think as long as you're asking for.
RainStryke
37
Yeah, you won't find extra long hoses on closed loop coolers. They build those for the masses and most people don't require the length of hoses you need. You will need to run a custom loop for that. I'd recommend checking into something like a XSPC watercooling kit. They are way more effective at cooling anyway.
