I need a keyboard for a POS system under 13" or As Small As Possible.
InlineFive
It's hard to find anything this size, and the normal sized keyboards are way too large to this purpose. Something the size of a Mac Keyboard would be nice but the POS wont work with those. Any suggestions?
Originally posted by: thorin
Rocket Science
http://www.google.ca/search?q=small+ps%2F2+keyboard&ie=UTF-8&oe=UTF-8&hl=en&meta=
The first results from this search:
http://www.google.ca/search?q=mac+keyboard+pc+use&hl=en&lr=&ie=UTF-8&oe=UTF-8&start=10&sa=N
http://www.trinityworks.co.jp/US/software/AppleKPro/index.php
Using AppleK Pro, you can even use a Mac USB keyboard on your Windows machine (ADB keyboards require a ADB/USB converter).
Thorin
Those links are useful but the POS requires PS/2. No USB, sorry. 🙁
Rocket Science
Thorin
psst
psst
*USB to PS2 adapter...*
I've seen lots of mini keyboards out there. Since you need ps/2, you can go all the way back to the 80s and find a used one.
Rocket Science
Thorin
psst
psst
Believe it or not, a USB to ps2 adapter is not a magical contraption that will make any USB device work with PS2. The hardware has to be made to support ps2, which keyboards, especially Mac keyboards don't.
Rocket Science
Thorin
You mean you don't have USB on the system you're trying to use the keyboard on?
Thorin
Rocket Science
Thorin
Thorin
It's a POS system that dosent support USB, only PS/2 so my options are sort of limited. 🙁
My USB ergo mac keyboard works just fine on my PC without anything special. Even detects the onboard USB hub. Only thing different is that the Windows key and ALT key get switched around.
Originally posted by: FreshPrince
What's your POS software? Looking for one here...
It's acutually specifically built for food cooperatives. It wouldn't serve any other purpose unless you talked to the designer and had him customize it for you. It's DOS based to save money, I dont know if you care or not.
POS fastfood kb
Thanks for the link but the POS designer made it with regular PC keyboards in mind, so I am not able to use anything way out of the ordinary. This makes it very difficult to find compact keyboards to use with it, even with all the links you people have very helpfully dug up! Thanks for the response though!
i'm not sure the exact dimensions you need, however this one looks to be a BIT smaller than most standard keyboards, keys look smaller and more packed on the board.. they give dimensions
http://www.evertek.com/viewpart.asp?auto=8514
then i found this thing, but it doesnt have a numpad, but its kinda cool
http://www.opc.com.au/IBM/catau.nsf/0/05c776159bfc6303ca256d36001fa3be?OpenDocument&ExpandSection=3
could you have a separate number pad? they make ps/2 numpads
last one i could find was here
http://www.keyalt.com/keyboards/compact101.htm
but its a little expensive, but definitly a full 101 key keyboard with a pretty good bit smaller, hope it helps, good luck
Thanks for all the help people! That IBM keyboard is really enticing but unfortunately we can't afford $169 for a keyboard not to mention a keypad along with it. 🙁 Unfortunately for me but this is starting to look impossible...
-Por
