I need a High flow 120mm fan for the front intake to cool MCP more...
DARQ MX
I need a High flow 120mm fan for the front intake to cool MCP more..."
New Message Preview
So what do you recomend like brands, place to buy and good prices...
I have a filter in the front and it has lots of conponets in the way and I need to get much better airflow in the case because I am changing my MCP's fan heatsink to a passive zalman heatsink cause the fan is starting to buzz.
Now I do Oc as you can see, and I know I will most likely not need it cause the Zalman HS will do fine on it's own, but incase I want to OC a bit higher I don't want my mcp to go on meltdown. haha...
http://sidewindercomputers.com/ >120 fans Delta Triple 120x38@79cfm=not cheap.
I have several of these very fine fans in 92x38 and 120x38 in use.
I don't like Chinaflos in 120x38. Tried'em don't like'em.
How much air do you want?? Do you have room for a 38mm thick?? They will drive more
air with less noise than a 25mm thick fan.
http://www.bgmicro.com/ >fans, the NMB thermally controlled fan 120x25@116cfm=$5.
Crush the thermistor, clean the metal ends, squeeze together, then solder=manually
controlled fan.
Are you going to use a fan controller?? Like a $9 Sunbeam Rheobus??
I have a few Sanyo Denki 120x38@102.5cfm@39dBA left. They run silent at 5V and will start/run
at that voltage. PM me if interested.
...Galvanized
