I need a FTP client for 10.5 ....
alfa147x
29,306
105
So im looking for a (free?) ftp client for 10.5
I need it to stand alone
thats about it...
Thanks!
alfa147x
29,306
105
Thanks Ill take a look at those, I used fireftp but Firefox doesnt run smoothly so I wanted a stand alone app thanks a bunch
TheStu
Moderator<br>Mobile Devices & Gadgets
Moderator
Sep 15, 2004
12,089
45
CyberDuck is great. Apparently it barely holds a candle to Transmit by Panic, but great nonetheless.
suklee
10
Does Transmit allow you to open more than one instance at a time?
I've just come from Windows where I could have multiple Filezilla windows open, connected to different sites. I found that I cannot do the same with FZ in OS X, unless I seriously missed something.
Edit: Did a quick browse on panic.com but doesn't look like Transmit allows this either. Is there another FTP client that can run multiple instances?
Edit2: looks like I was wrong. Transmit appears to support multiple windows. :thumbsup:
Tabs
Many connections, one window.
Now just need to figure out how to convert from Filezilla's XML into Transmit Favorites. <<< Is this possible? Can't find much on Google.
sourceninja
8,805
65
I loved cyber duck, until I had to transfer 300 small files to a server. After 8 minutes I closed it, downloaded filezilla and had the files uploaded in about 1 minute. Sure filezilla is ugly as sin, but it works.
silverpig
27,703
12
Cyberduck is SLOW on a LAN. I have a 100 Mbit LAN at home and was transferring some movies from one computer to another. Cyberduck ran at 10 Mbit speeds. I switched to fetch, 100 Mbit.
jhu
11,918
9
open up the terminal. type "ftp". there you go!
there's also a utility called "curl" that should come standard on a mac os installation. if you're good at writing shell scripts, you can use that to automate mass downloads/uploads
suklee
10
Just want to report back that Transmit is great... I'm using it in conjuction with Textmate and when I save a file in TM (opened from Transmit) it automatically uploads it back onto the server. Fantastic... I couldn't do this in Windows.
