I'm currently pulling together a build that's most likely to be an i7 setup with an ASUS P6T and SLIed 8800GTs. My current case (not being recycled) is a Thermaltake Soprano with dimensions of 19.5" x 8.3" x 18.9" and not really enough room inside. Because the hard drives mount straight in, I had to forgo the intake fan to cram the HDs (a mix of PATA and SATA) as far forward as possible to clear the length of the 8800 GTs. Not good and no way to fit a GX2xx or similar video card.
So, just buy a bigger, deeper case like the ENERMAX Uber Chakra and the problem's solved, right? WRONG! It's too big to fit under my desk. Heightwise, the top USB ports are lost because my keyboard tray just clear the tower's height, and it's too deep to fit under. I need something about 20" on a side (H & D) though I can go a bit taller. (I had an Antec SH1030 that fit fine.)
My previous rig was built in Aug. 2003 in an Antec Sonata case which had sideways HD mounting and if I could find a case that picked up the room that today's huge mobos and GPUs need by mounting that way and still fits under the desk, that would be ideal. I just don't know what fits that bill.
I currently have a windowed case and that's cool, but not mandatory. I need a roomy case with good airflow, but that is still fairly quiet. Any suggestions? I'd like to keep the price under $120 if possible. I'm not looking for something that looks like it should turn into a Gobot either - I'm not 15-years-old. Thanks!
