i need a case. Sugestion?
twitchee2
I need a case but it needs to be under 60-70 bucks. i dont care about the psu im getting a better one. only reqire is that i has a acrylic window and at least one fan(preferably 2).
thanks in advance.
please supply links
I just bought one of these (replaced the psu though). So far, so good. I'm replacing the front 80mm intake fan with a 120mm fan tomorrow, the screw holes are already there, in the right spots. (Which makes me wonder why they didn't slap in a 120mm intake to begin with?)
I like the Aspire Dreamer case you mentioned, a friend has this one and is very pleased with it. I sliced my index finger something fierce though installing an hdd into it, so if you get one watch those sharp edges, hehe.
i had a antec super lanboy once. you can take the door off. just requires some force. pretty nice case imo. just a little too small for my tastes. now i have a antec p160 case. this case is perfect.
Originally posted by: D1gger
I like the Tsunami Dream case from Thermaltake.
I have this one also. I've been pleased with the top-mounted USB ports since I always have my system on the floor, and the front mounted ports are never very accessible as a result. It's a little louder than I wanted though -- still need to find a 5V fan controller to slow down the 120mm fans even more (using 7V right now, lowest I could find). It's quiet, but not nearly silent (CPU cooler is silent, however).
Originally posted by: Amaroque
I prefer Lian Li cases. They don't come with a PSU, and are expensive, but are by far the best quality cases ever I've used.
Just curious, but have you ever used a case from PC Power & Cooling? I had their midtower some years ago, and I've yet to find another case with the same build quality. I still have it, but it doesn't have front USB ports or anything like that (it's in my closet).
No, I haven't. But I imagine PCP&C being top quality also.
Anyway, I'm using the PC70usb (no clear side panel, I think that's dorky). It's huge! But it's very cool & quiet, with 6 case fans running at very low RPM.
My V2100B arrived from NewEgg yesterday. This thing is huge...🙂
Let us know what you think of it, I need another quality case. 🙂
yea i really like the lain li only problem is i only have $70 max to spend on a case 220 is a lil out my budget 🙁
I am hoping to have it up in about 2 weeks...I'm waiting on some parts and need to mod my power supply.
It really is a nice case. Should fit my 5 x 250GB HDs fine😉
thansk for the info does anyone else have annymore sugestion remember i dont want to spend over $70 on the case and i dont care about the PSU
