Originally posted by: AMDfreak
Mountain Mods U2-UFO for the win. Doesn't get much bigger than that without a custom job.
True!
And, Mountain Mods WILL make you a 'custom job' to your spec!
Tell them what you want. They'll give you a price and a completion date -- and it'll happen when they say, at the price they quoted you...
Mountain Mods is #1 :thumbsup:
*edit*
NOT AT ALL my cup o' tea, but here's
an example (custom job)...
WOW! - Double Trouble. ok, what I've got in the case: amd-fx-57 cpu asus a8n-sli premium mb 4 gigs corsair xms pc3200 ram 2 7800 gtx evga 256mb vid cards 2 74 gig raptors[wd-hd] 1 pc power and cooling 850 watt ps 1 400 watt sunflower ps[for fans] 1 thermalchill pa-120 raditor 2 u2-ufo brushed aluminum cases[painted and modded by tailored pc] 1 awaki water pump 1 alpha cool reservoir danger dan nv-78 sli copper 1/2" id vid card water block kit 1 whitewater cpu water block 1polar duel water block kit for hd's 2 matrix orbital mx230 lcd displays for system info 1 ati theater 550 pro chipset/ beyond tv-tv tuner card 1-hp 16x dvd+/-rw lightscribe drive 1 sony 16x dvd drive 22 case fans-20 120mm-2 80 mm 1tailored pc water-cooling emergency shut down system w/power supplies and pump relay 2 tailored pc fan controllers controls all fans[two for intake -two for out take 3 tailored pc fan divertors-3 fan-6 fan- 9 fan 1 set green ram lighting 1 tailored pc lights pcb for single control for uv an cold cathode lights and ram 4 12" cold cathode green lights 2 12" uv lights 1 x-fi fatality sound card all custom wired with green and black cables green led fans in front and top of case all aluminum case fans for back. also have two 6" 1/2" water heat exchangers-black had them welded together and custom windows built for the case, is 3' tall and 18" square. had a custom built power supply bracket and additional bracing done to support this case.
I love my mountain mod cases and its the best case I've ever owned and would highly recommend this company for any of your case needs
I guess I got some hillbilly blood in me, but
this is more to my liking (regular case)...
