- Jan 12, 2005
- 1,351
- 29
- 91
Where can I find one. My board has a two pin powere led and my case has a 3 pin female plug. I can't find one. Anyone know where I can get one.
Originally posted by: montag451
I just cut the connector with a stanley knife, and plug it in.
Originally posted by: WobbleWobble
You can pluck out the connector from the plastic and stick it in the other hole.
Originally posted by: ingeborgdot
When you cut it you mean just cut it in half and then put the one hole over the one male end and then put the other over the other male end and then have the wireless hole out in no where land. That will be a lot cheaper than buying some connector which I can't find anyway.
