I keep double posting...
aphex
Moderator<br>All Things Apple
Moderator
Jul 19, 2001
38,572
Not sure if anyone else is getting this as well...
But for some reason i keep double posting (does it with both WYSIWYG and regular editor)...
Im only clicking the 'Post Message' button once, and when it comes up there are two messages...
Is this a known issue? or is it just me?
Zim Hosein
Super Moderator | Elite Member
65,467
408
aphex, I'm made a bunch of posts tonight w/o and double posts. To help Zuni narrow it down, are you a subscriber or non-subscriber?
aphex
Moderator
Jul 19, 2001
38,572
Non. Using XP/IE6 on a 2ghz Atlhon w/ cable modem.
I've had 4-5 double posts today, when i havent had more than one in the 2 years ive been here...
aphex
Moderator
Jul 19, 2001
38,572
Originally posted by: Zuni
What are you doing to produce it havent seen it here.
heres one that just happened... Just posted as normal yet 2 posts show up... I've heard a few other members mentioning the same as well.
update: one more from just a minute ago, looks like someone else double posted as well.
rudeguy
47,351
14
61
its happening alot since the upgrade Zuni....is there any way to adjust the flood protection? Its been happening to me if my connection is going a bit slow, or I accidently hit the reply button....here and here those were when my connection froze in the middle of posting....this is a thread of everyone discussing the double posting matter
Barnaby W. Füi
12,343
Maybe make it so it will refuse posts that have a frequency of more than every 5 or 10 seconds (don't make it too high, those atot nefs will raise a fit ;))
Spyro
3,366
Originally posted by: BingBongWongFooeyx2
I think you can now hit the reply button more than once and it doesn't stop you.
Actually sometimes it does and sometimes it doesn't...... :confused:
Spyro
3,366
Jason Clark
Its not off it was removed for a new system, that is not enabled, but probably will be soon. The old system had a lot of issues with censored words etc.
Jason Clark
Nope, the old system interfered with that check, essentially you lost your post if forbidden words were found on a flood post. Censoring is still in place, and always will be.
