My parents' computer stopped working out of the blue, so I decided to swap out some parts (from my computer) to figure out what was wrong with it. Eventually I decided it was most likely the motherboard. That's the first dead computer.
The second one, mine, died shortly after the testing, and I'm not sure why. I decided to borrow the stick of ram from my parents computer as they wouldn't be needing it, but once I got it in (taking up the fourth slot in my Shuttle ak31 motherboard) windows wouldn't load. The computer would POST, but it wouldn't load windows. So I took out the last stick, made sure with windows would load like that (which it did) and then I decided to give the fourth stick one last try.
This time it was really hard to get it in for some reason, and my motherboard sort of bent more than it should. This time when I tried to boot up, instead of the usual screen, I got no response from the monitor and a loud beep from the motherboard. When I pulled out the power on my computer, it smelled like something had gotten fried. It shouldn't have been the CPU, as I'd checked earlier that the heat would stay put after I was done swapping out parts, and I hadn't changed anything since then.
Does anyone have any idea what the problem might be?
Other things to note:
Both computers are using Shuttle ak31 motherboards, with athlon xp 1700+ cpus.
Now when I plug the power into my computer, fans and things start up but stop abrubtly. I then have to hit the power button to get things going again (previously whenever I plugged the power in the computer would just start up).
I've tried resetting the CMOS on both computers.
If anyone wants any further information about either computers I'd be glad to supply it. I really hope you guys can help me.
