Help i have a j-7XA PCI/AGP M/B For Pentium II Processor motherboard and it says if i put a 128meg DIMM into my one of three DIMM slots i cant put anything else in the other 2. Is this right and could it work anyway. ( i already have two 32's in there).
Thanks
I think that you should be OK, I guess that you have a 440LX chipeest, which supports up to 768Mb of RAM, to get that you have to have 256Mb in each, it is only 512MB DIMM's I would have thought that wouldn't work
