VirtualLarry
- Aug 25, 2001
- 56,542
- 10,167
- 126
Some general good ideas can be found here:
http://forums.anandtech.com/showthread.php?t=2408108
If spyware/hijackers are obvious, turn off system restore.
Go to programs and features and remove toolboars and questionable programs.
Open up msconfig and deal with programs are allowing the intrusion through.
Clean out user temp folders.
Clear browser history and any add-related toolbars still installed.
After that, Superantispyware and Malwarebytes for anything else.
I have used VLC for years and never seen a pop up like that.
New malware is using popups trying to "inform" you to update software on your computer, only to provide you a download not of the updated software but some other malicious software to execute.
I know. I almost felll for it, but I was blocking scripts and knew that pop up for flash couldn't have been generated.
The OP more than likely has a PUP/adware and I bet ADwcleaner gets rid of it.
i tried running malwarebytes in safe mode, it finds nothing but im still getting the popups
i think im going to reformat, i want to upgrade my hd anyways and ill need to reinstall windows + a few games
Its still there guys, after running Malwarebytes in Safe Mode and ADWCleaner, which said it found 34 things, but then today the pop ups are back.
im just going to reformat, i bought a new hard drive, i am going to use the 500gb for OS and 3tb for games
evenetually the 500gb will be swapped out for an ssd as well
Windows 7: Warning - KB3004394 corrupts system files..
http://borncity.com/win/2014/12/10/...tificate-in-windows-7-windows-server-2008-r2/
http://www.sevenforums.com/windows-...-warning-kb3004394-corrupts-system-files.html
Problems with update KB3004394.. Google it..
Microsoft screwed the pooch..
Is it possible that you have ROUTER malware? If your router was set to a default password and IP address, then this is possible. Something might have changed your DNS settings in your router, such that your web accesses for things are being re-directed through a proxy site, that is injecting those ads into your HTTP stream, and interfering with Windows Update.
Just a theory, at least. Worth checking out.
Edit: That would explain why Malwarebytes didn't find anything on your machine.
my router was secured with a private password. how common is router malware?
