otispunkmeyer
i jus got UT2004 and was totally disapointed by the way it played my system (a XP2000, 512 PC2100, 9500pro) obviously isnt up to par. and i had everything set to LOW or NORMAL at best.
i had read some where about changing the the multiplier and v/core, so i though lets give it a try.
currently the multiplier was 12.5 x 133 , so i tried it on 14x133 which the bios had no trouble telling me i shouldnt...i am aware of the extra heat oc'ing incures but i have a Vlocano 9 with smart fan so i figure im alright. now this mobo can take upto xp3000 of the same type core palomino i think so changing the multiplier shouldnt do much.
how ever i saved the settings and it rebooted.........all i get now is a blank screeen an the lights on my CD drives flash for abit and thats it.........the screen turns off as if there is no signal and the computer jus does nothing
i have tried to clear the bios ram memory thing with the jumper but i get the same result!!!!!!!!!
any help? thanks
any help? thanks
